Nouveau pont de RC4WD
Discussion dans 'News Crawlers / Scales' créé par Rockatanski, 2 Août 2014.
  1. Rockatanski
    Rockatanski membre
    28 Avril 2012
    [TABLE="width: 98%"]
    <tbody>[TR]
    [TD="colspan: 2, align: center"][/TD]
    [/TR]
    [TR]
    [TD="colspan: 2"][TABLE="width: 100%"]
    <tbody>[TR]
    [TD="align: left"][/TD]
    [TD="align: right"][/TD]
    [/TR]
    </tbody>[/TABLE]
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 2"]DESCRIPTION[/TD]
    [/TR]
    [TR]
    [TD="colspan: 2, align: center"][TABLE="width: 100%"]
    <tbody>[TR]
    [TD][​IMG]
    D44 Narrow Front Axle (SCX10 Width)
    • D44 Differential Housing (Z-S1030)
    • D44 Narrow Front Axle Tubes (SCX10 Width) (Z-S1023)
    • D44 Axle C Hub (Z-S1029)
    • D44 Steering Knuckles (Z-S0955)
    • XVD Axle Shafts for D44 Narrow Front Axle (SCX10 Width) (Z-S0989)
    • D44 Lower Link Mounts for SCX10 (SCX10 Width) (Z-S1022)
    • D44 Panhard Mount for SCX10 CMS (SCX10 Width) (Z-S1071)
    • D44 Narrow Front Axle Upper Link Mount (SCX10 Width) (Z-S1024)
    • D44 Link Set for SCX10 CMS (SCX10 Width) (Z-S1072)
    • 2x 12mm Hexes (Z-S0238)
    • M2 x 10 Axle Hex Pins (Z-S0277)
    • 4mm Lock Nuts (Z-S0620)
    Bearings:
    Notes:
    • Pour Installation dans le SCX10 chassis le RC4WD SCX10 CMS kit est neccessaire (Z-S0923)
    D44 Narrow Rear Axle (SCX10 Width)
    • D44 Narrow Rear Axle Tubes (SCX10 Width) (Z-S1021)
    • D44 Rear Axle Bearing Caps (Z-S1073)
    • D44 Narrow Straight Rear Axle Shafts (SCX10 Width) (Z-S0899)
    • D44 Rear Axle Upper Link Mount (Black) (Z-S0971)
    Bearings:
    D44 Wide Front Axle (Wraith/AR60 Width)
    • D44 Wide Front Axle Tubes (Wraith Width) (Z-S1027)
    • XVD Shafts for D44 Wide Front Axle (Wraith Width) (Z-S1020)
    • D44 Lower Link Mounts for Wraith (Wraith Width) (Z-S1026)
    • D44 Panhard Mount for Wraith CMS (Wraith Width) (Z-S1074)
    • D44 Wide Front Axle Upper Link Mount (Wraith Width) (Z-S1028)
    • D44 Link Set for Wraith CMS (Wraith Width) (Z-S1075)
    Bearings:
    Pour Installation dans le Wraith le RC4WD Wraith CMS kit est obligatoire(Z-S0647)
    [/LIST]
    D44 Wide Rear Axle (Wraith/AR60 Width)
    • D44 Wide Rear Axle Tubes (Wraith Width) (Z-S1025)
    • D44 Wide Straight Rear Axle Shafts (Wraith Width) (Z-S0990)
    Bearings:
    Notes:
    • In order to complete the axles, you will need Axial/HPI pinion and ring gears, diff/locker. - sans les axial pinion et ring gears
    • The Lower Link Mounts are made to be Interchangeable.
    Axial Components Required to Complete:
    Neccessaire pour completer les ponts:
    Instruction Manual:
    [/TD]
    [/TR]
    </tbody>[/TABLE]
    [/TD]
    [/TR]
    </tbody>[/TABLE]
  2. dreufic
    dreufic Guest
    Pas mal mais encore à des années lumière de la qualité de finition des ponts VP Currie !
    :ang3:
  3. Teddy
    Ils ont surtout des voies étroites pour faire de beaux scales avec des roues qui dépassent pas dans tout les sens :yeah3: !!
    Va falloir que je me penche dessus pour mon prochain Hilux.
    :intell3:
  4. sasacécé
    22 Octobre 2011
    Jolie ses ponts.... :yeah3:
    Par contre les petits ne me semble ps beaucoup moins large des des YOTA si je ne dis pas de bêtises..... :jecpa3:
  5. hanjin-san
    Ils ont la même largeur que des ponts Axial et ils en reprennent la mécanique interne, un peu comme des ponts VP quoi... :wink3:
    Par contre à voir pour la compatibilité des cardans, c-hub et fusées d'autres marques :sarcas3:
  6. Teddy
    Ah bah mince alors... Je croyais que c'était les remplaçant des "je ne sais plus leur nom".
    :grrr3:
  7. sawblade
    ils sont bien scales :yes3: me font penser aux SDI...
    je les verrais bien sur un def ou un land... tip top sur mon 109 pour avoir "les roues en dedans"
  8. sasacécé
    22 Octobre 2011
    Je pense que tu parle des t-rex 44 qui etiant bien car tres peut large... :smile3:
