HPI Venture
Discussion in 'News Crawlers / Scales' started by Grigri, Jan 26, 2016.
  1. edf84
    edf84 membre
  2. Grigri
    Grigri membre
    Vu sur RCMart
    HPI is releasing a 1/10 Scale Crawler called the FJ Venture. As the name suggests, it will come package with a FJ body. Only seen in previous RC4WD trucks, the FJ Venture will come with a front mounted motor and a transfer case in the center to bring power to both the front and rear wheels.
    Judging by the life sized Toyota FJ, the wheelbase of this car will be somewhere around 260mm. By running a transfer case in the middle, means that the chassis clearance will be higher as there is not much located at the center of the chassis!
    Standard 4-link suspension and aluminum coil over shocks similar to the style seen on the Axial’s SCX10 can be seen in the photo below. The front and rear bumpers with the various scale items are now a common site on almost all scale crawlers and can be seen to be included in this truck.
    A chassis mounted servo (or more commonly known as CMS) seems to be standard on this truck, whereas on other chassis’s they are a option part!
    One thing we didn’t really like were the lower links are attached fairly close to the wheels when compared to other trucks. This results in the lower link spanning across the lower chassis and may snag on obstacles on the trail!
  3. sasacécé
    Si l'empattement est de 260mm , sa ne sera certainement pas énorme comme gabarit....:)
  4. Rubicon69
    Rubicon69 membre
    pour compléter le sujet , je confirme carrosserie en lexan et une vidéo de présentation et des photos
    il me fait de l'oeil ;) je me laisserai bien tenter, ça respire la qualité de fabrication HPI, affaire a suivre après premier retour
  5. edf84
    edf84 membre
    C'est possible, car même le Crawler King HPI que l'on voit a coté sur certain photo de Nuremberg, et qui parait gros, ne fait que 238mm d'empattement. Donc a voir quand ils auront mis plus d'info sur le site HPI.
    Par rapport a un Gelande 2 RC4WD qui fait 275mm d'empattement pour le Def90 et 331mm pour le Def110, ce serait alors un peut plus court...
    #25 edf84, Jan 28, 2016
  6. hanjin-san
    Moi je pense plutôt qu'il a un gabarit similaire à un Ascender. En tout cas cela n'aurais aucun intérêt de proposer un modèle plus petit que la concurrence...
    edf84 likes this.
  7. mugen38
    par contre je trouve dommage de déjà" vouloir " lui changer de carro à ce scale par ce que moi je ne l'achèterai que ... pour ça ... déjà !!! :passur:
    Diot73 and Grigri like this.
  8. yann du 34
    yann du 34 membre
    Salut en tous cas moi il me plait vraiment, a voir en vrais :)
    mugen38 likes this.
  9. hanjin-san
    C'est comme tout, c'est une question de goûts et de couleurs, on aime ou pas... De plus, le fait qu'elle soit en Lexan peut aussi être la raison du changement pour certains...
    mouais ... mais quand même !!! :passur:
  11. Fred 16
    Fred 16 membre
    (y)(y)(y)(y)(y)(y)(y)(y)(y)(y)(y)
    mugen38 likes this.
  12. hanjin-san
    La carrosserie est très sympa et originale mais si le châssis se révèle être une très bonne base, beaucoup ne vont pas se priver je pense... ;)
    edf84 and Alex07 like this.
  13. edf84
    edf84 membre
    Je le trouve pas mal du tout, comme ça, avec sa carrosserie texan de Toyota et au début il roulera certainement comme ça pour moi aussi.
    Mais j'aime beaucoup le look des Defender 90 ou 110, c'est pourquoi quand j'aurais ce nouveau Scale HPI, je regarderais si il est possible d'y adapter une autre carrosserie de ce type.
  14. edf84
    edf84 membre
    Vu sur la page Facebook du Venture FJ HPI Venture
    L'empattement serait de 311mm (12.3")
    Donc dans la ligné des autres Scales de cette échelle.
  15. ONOFF
    ONOFF membre
    Le problème des premiers kit sortie c'est quand général la carro est déjà peinte et du coup tout le monde à le même.:humhum:
  16. Futabarex
    Futabarex membre
    C'est vrai qu'il est superbe et le châssis paraît très qualitatif.
    Et puis HPI c'est le roi de la caro et ils ont l'habitude de sortir plein de déclinaison d'un même chassis avec pour seule modif des caros plus belles les unes que les autres. Pas de raison qu'ils ne fassent pas pareil avec ce Toy !
  17. esox88
    esox88 membre
    moi aussi j'aime bien la gueule de ce toy ^^ il est sympa et sa change un peu de tout ce qu'on voit habituellement !
  18. Rubicon69
    Rubicon69 membre
    Certainement mon prochain achat, la finition a l'air top, quelqu'un connaît la date de sortie ?
  19. bipbipzz
    bipbipzz membre
    magnifique j'adore HPI
    photo Savage thermique modifier en électrique avec moteur titan du summit
  20. Futabarex
    Futabarex membre
    D'après mon magasin habituel, il n'y a pas de dispo connue à ce jour.
    J'espère aussi qu'ils vont se bouger chez HPI pour nous sortir ça rapido car parfois c'est pas tjs le cas avec eux :mad:
