Axial SCX24, SCX10 et maintenant SCX6
Discussion dans 'News Crawlers / Scales' créé par Jippi, 14 Octobre 2021.
Tags:
  1. Jippi
    Jippi membre
    5 Mars 2017
    Axial sort une version 1/6 du SCX : le SCX6 à 1099$ RTR
    The new Axial SCX6 1/6 scale crawler.
    Early preview model due in this Friday.
    Stop in and check it out.
    Scale: 1/6
    Length: 33.55" (776mm) - JL 1/1=4882mm donc échelle réelle=1/6.3
    Width: 14.88" (378mm) - on ne peut pas calculer une échelle sur une largeur, car ce n'est pas un class 1
    Height: 14.55" (370mm)
    Weight: 25lbs (11.3kg)
    Ground Clearance: 4.25" (107.9mm
    Wheelbase: 19.74" (501mm) - on ne peut pas calculer une échelle sur un empattement, car c'est adapté pour que le châssis soit compatible avec la carro.
    Jantes en 2.9', pneus 178mm
    Chassis: Stamped Steel
    Shock Type: Oil-Filled, Coil-Over Springs
    Drivetrain: 4WD (locked front and rear)
    Differential: Locked
    Ball Bearings: Full ball bearings throughout
    Features
    • New 1/6 scale chassis design is based on the proven SCX10™III
    • Includes AR90 standard axles with a Heavy-Duty Spool
    • Metal gear transmission comes pre-configured for two-speed action (High-speed and Low-end gearing)
    • Durable three-link front and four-link rear suspension setup provides optimal handling
    • Replica V8 engine cover adds to the realistic appearance
    • Detailed Jeep JLU Wrangler body includes functional LED headlights and taillights providing exceptional scale looks
    and performance
    • High-traction, 7" tall BFGoodrich KM3 tires, pre-mounted on Black Rhino Primm 3-piece beadlock wheels
    • AMAZING New Spektrum Electronics featuring:
    o Spektrum DX3 2.4GHz DSMR radio provides superior range, response, and interference resistance and is
    compatible with Smart technology.
    o Spektrum Firma Crawler 120A ESC feeds telemetry data to the DX3 transmitter in real time
    o Spektrum S905 Large Scale Metal Gear steering servo (also accepts larger 1/5 scale servos with the included
    adapter)
    Et en vidéo :
    Something Big... Casts it's Shadow... A Giant Approaches!
    #1 Jippi, 14 Octobre 2021
  2. Reptile81
    Reptile81 membre
    Différentiel bloqué (n), alors que là il y a la place pour mettre un blocage a distance:D
    J'attend de voir plus de photos
    Nicolas apprécie ceci.
  3. gicab
    Intéressant… faut le terrain de jeux qui va avec… ouf j’ai pas de grand désert américain :hihi:
  4. Nicolas
    Ils auraient pu élargir leur gamme de 1/8 (nommé 1/10) en proposant des vrais scale avec blocage de diff, abs, intérieur, ....
    Ou alors faire dans le vrai 1/12 qui ce dévelope.
    #4 Nicolas, 14 Octobre 2021
  5. Manhattan
    Je trouve qu'au tarif annoncé, on est en droit d'attendre mieux qu'un SCX10 iii simplifié et agrandi à la photocopieuse.
    dawii, Nicolas et Reptile81 aiment ça.
  6. Olivdegre
    Olivdegre membre
    30 Mai 2021
    A tarif inférieur, traction hobby fait mieux :humhum:
  7. gicab
  8. Morgan86
    Longueur: 4880/776 environ 6,2
    Largeur: 1890/378=5
    Proportion pas vraiment respectée je pense (ou c'est à cause des pneu qui dépassent sur le axial)
    C'est un peu chère effectivement même avec le brushless d'origine.
    #8 Morgan86, 14 Octobre 2021
  9. Scal68
    C'est normal qu'une marque comme Axial s'attaque au créneau 1/6 vu le succès rencontré par Rochobby avec la Willys et ptet aussi un peu Capo avec le Sixer.. Mais les scaleux sont ils prêts à investir dans cette échelle ? Perso je reste sur le 1/10 (1/8?) qui prend déjà pas mal de place (et de budget :humhum:) Question de choix..
    Et puis ça serait pas mal qu'une telle marque nous mette une patate avec un modèle original inattendu, après tout ils doivent avoir le budget et Rochobby l'a bien fait avec la Willys et dernièrement la ch'tite Suzuki.. Ils ont osé et on a vu le résultat.. :humhum:
    dawii, zeb, fb11 et 2 autres personnes aiment ça.
  10. Nicolas
    - Axial SCX24 - Jeep Wrangler (vendu pour du 1/24) Échelle moyenne calculée = 1/20.5
    Largeur Réel / RC ( échelle ) = 1880 / 99 ( ech : 1/19 )
    Empattement Réel / RC ( échelle ) = 2947 / 132 ( ech : 1/22 )
    - Axial SCX10 - Jeep Wrangler (vendu pour du 1/10) Échelle moyenne calculée = 1/8,8
    Largeur Réel / RC ( échelle ) = 1880 / 226 ( ech : 1/8,3 )
    Empattement Réel / RC ( échelle ) = 2947 / 313 ( ech : 1/9,4 )
    - Axial SCX6 - Jeep Wrangler (vendu pour du 1/6) Échelle moyenne calculée = 1/5.35
    Largeur Réel / RC ( échelle ) = 1880 / 378 ( ech : 1/4.9 )
    Empattement Réel / RC ( échelle ) = 2947 / 501 ( ech : 1/5,8 )
    Comme d'habitude les échèle chez Axial, c’est a la louche et une grosse louche. :hihi:
    Un gros scx10 sans aucune innovation. Je crois qu'Horizon Hobby a supprimé le bureau d'étude d'Axial et de Vaterra.
    RVB42, dawii, Daug et 1 autre personne aiment ça.
  11. sawblade
    Mis à part le budget, ça me fait bien envie. Surtout en config simpliste (pas de diff debloquable.
    Ce serait parfait pour les grosses caillasses !
    Bon, vu le prix, même pas en rêve...
    dawii, zeb, Daug et 3 autres personnes aiment ça.
  12. Olivdegre
    Olivdegre membre
    30 Mai 2021
    Presque le double du prix d'un absima Yucatan, et plus de 20% de plus qu'un traction hobby founder 2 pour bien moins d'options ... Delly et moi on aime bien les grosse machine parce ce que ça crapahute bien et que nous sommes pas trop a cheval sur les échelles exactes et le côté ultra scale mais là je trouve que 1100 c'est beaucoup ! Point de vue purement personnel ...
  13. Olivdegre
    Olivdegre membre
    30 Mai 2021
    Oui a 150/200€ de plus qu'un scx3 1/10 pour compenser l'ajout de matière, mais pour aucune innovation 500 de plus ça fait beaucoup non ?!?
    dawii et sawblade aiment ça.
  14. Olivdegre
    Olivdegre membre
    30 Mai 2021
  15. CyberFox
    CyberFox membre
    17 Mars 2009
    Nicolas, plus c'est grand et plus ça se rapproche quand même, alors je suis sûr que le SCX4 sera un vrai 1/4 :hihi:
    dawii, zeb, Daug et 2 autres personnes aiment ça.
  16. CyberFox
    CyberFox membre
    17 Mars 2009
    80 cm de long, c'est énorme! C'était la taille du Baja 5b il me semble ?
    Là en plus avec une carro entièrement recouvrante, ça doit faire encore plus maousse... à quand le poids lourd (echelle 1!) pour transporter ses R.C. ? :eek:
    dawii, zeb et fb11 aiment ça.
  17. gicab
    Regarde quoi de mieux que de faire n’importe quoi avec :confused: tu es en panne pas de panique j’ai mon axial 1/6 :hihi:
    dawii, Daug, fb11 et 1 autre personne aiment ça.
  18. Manhattan
    En aéromélisme ils ont bien fait des warbirds au 1/3 (le tempest du couple Wild) :
    Furaventos 09 desbloqueada - zero-zero
    Le Club
    #18 Manhattan, 14 Octobre 2021
  19. CyberFox
    CyberFox membre
    17 Mars 2009
    ah tiens, bien ça pour aller chercher les enfants sans sortir de chez soi, avec une caméra et une commande longue portée... :D
    dawii, fb11 et gicab aiment ça.
  20. gicab
    le grand nous a quitté pour 100% indépendant… et l’école de ma grande est trop loin :hihi:
